Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Tahoe
Engine
Wiring
Engine wiring diagrams camshaft sensor low voltage?
2004 CHEVROLET TAHOE
200,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
SWINT
MEMBER
1 POST
Knock sensor low voltage, camshaft sensor low voltage,mass air flow low voltage,shift solenoid b low voltage.
Jan 11, 2021 at 5:20 PM
Experienced Mechanic
Good morning,
What was the voltage at these sensors?
Are there any codes set for this issue?
All sensors should have 5 volts and all actuators and solenoids need 12 volts. I attached the wiring diagram for you to view.
I would also check the battery to be sure it is good.
Images (Click to enlarge)
Jan 11, 2021 at 7:56 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
