Low engine idle speed?
112,000 MILES • 6 CYL • 2WD • AUTOMATIC
SERENITY 1
All is normal except the RPMs has been lowered all of a sudden?
Oct 15, 2022 at 7:44 PM
  • 55,721 POSTS
Yep, this can happen if the throttle body needs service or there is a vacuum leak. here are three guides to help us fix the problem. Also, we should run the codes as well.
And do this guide when the engine is cold only:
And to get the codes:
Please go over these guides and report back.
Oct 16, 2022 at 6:06 AM
