High engine idle?
600,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
KHURRAMNCP
  • 14 POSTS
In the morning the RPM goes to 1500 at startup and then slowly decreases to 900. The engine vibrates a lot in idle mode. New throttle body has been installed but no improvement. Sometimes engine is not is not started in first attempt.
Oct 16, 2022 at 1:02 PM
  • 55,710 POSTS
This sounds like a classic vacuum leak. Please check for leaks by following this guide when the engine is cold:
Also, this guide may help as well:
https://www.2carpros.com/articles/engine-idles-too-high
Please go over these guides and report back.
Oct 17, 2022 at 2:58 AM
