Low range message but have gas
101,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
DIANE CAMPBELL
I have three quarters of a tank of gas, yet get the message "low range". Car will not start and does not crank over, although the dash and headlights have power and battery is fine.
Jan 9, 2018 at 11:06 AM
  • 55,721 POSTS
It sounds like the dash integration module is having problems but to be sure we should check the fuses to make sure they are all good. ALDL and voltage check fuses.
Here is a guide to help you:
Check out the diagrams (below).
Please run this test and get back to us.
Cheers, Ken
Jan 11, 2018 at 5:04 AM
