Low power and runs hot
120,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
RVSJR
Car starts easy, idle smooth, has very little power runs hot.
May 7, 2021 at 6:21 AM
  • 110,251 POSTS
My first thought is a plugged catalytic converter. Are there any odd sounds or smells from the exhaust? If so, remove an oxygen sensor before the converter. That will allow additional airflow. It won't be perfect, but if the converter is plugged, you will notice a difference in power with it out.
Also, take a look through this link. Let me know if what you experience mirrors what you experience.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Here is a link that shows how to test one:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
May 7, 2021 at 3:00 PM
