Reduced power light and engine light
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLUEMOONE
Codes have been done by mechanic shop, oxygen sensor, catalytic converter both new, map sensor new, TBS, new throttle body new, injectors new. Says EVAP system, cannot find diagram for this, and seems clearing codes do not work have same issue.
There is a electronic module? with 2- vacair lines on driver side top of motor no-one can find what it is, it is injuction with fuel EVAP system.
Jun 12, 2018 at 6:41 PM
BLUEMOONE
These items are on driver side of motor on top, one on fuel EVAP other is on intake, back side. No identification or numbers to cross reference. All codes run same with New parts oxygen sensors 1 bank and 2, catalytic converters, fuel lines, fuel pump, plugs wires, injectors, still low power light and engine light, if clear as driving runs great fifteen minutes, all lights turn back on. No power.
Jun 14, 2018 at 7:18 AM (Merged)
Good afternoon.
Lets start with the codes. What are the exact code numbers?
As far as the low power, have you checked the compression to be sure the timing belt is in good shape?
https://www.2carpros.com/articles/engine-has-low-power-output
https://www.2carpros.com/articles/how-a-timing-belt-works
Jun 14, 2018 at 7:36 AM
BLUEMOONE
Low power is not engine issue.
Jun 18, 2018 at 9:36 AM
  • 55,561 POSTS
Lets run the codes to see what comes up. It sounds like to me this can be a throttle bore issue. Please let me know the codes.
Cheers, Ken
Jun 18, 2018 at 9:38 AM
