Hello, my suburban seems to have trouble when I give it full throttle at highway speeds especially up hill. It will make a lot of noise but with no real increase in speed unless I back off the throttle a little, only then will it start picking up more speed. Power at half throttle feels fine but there is some surging. The engine will sound like it is being muffled a little when I'm at full throttle. I have cleaned the entire throttle body (the pcv port and partially the line to the pcv valve was completely clogged, also cleaned the pcv valve a little) and changed the fuel filter. This helped a lot with the power issue I was having before. I'm wondering if it can be an EGR valve or related sensor or even a bad pcv valve still. Also can a bad emissions canister cause the problem? Any help will be appreciated. Thank you.
Jun 20, 2014 at 8:02 AM
