Low Pitched Whistle noise coming from ECM
1997 DODGE CARAVAN
162,000 MILES
RWYGANT
Low pitched whistle noise coming from ECM, just had a complete tuneup plugs, wires, rotor, distributor, and pcv also checked for any vacuum leaks there were none put ear right above ECM next to battery and behind driver side headlight and whistle noise def coming from the ECM. Problem with ECM cropping up?
Apr 20, 2013 at 1:15 AM
yes as there should be no noise at all from the pcm
Apr 20, 2013 at 1:53 AM
