Low pickup, low boost
113,000 MILES • 4 CYL • TURBO • MANUAL
SANAMOTORS
Actual vehicle is Ertiga zdi. Firstly vehicle was emitting black smoke due to turbo. I have changed turbo. Vehicle has stopped emitting smoke. But pickup is very low. At 2,500 rpm's vehicle is not going over 60 kmph. EGR valve is also cleaned. Catalytic converter is also cleaned. Mass sensor is okay. But problem is not resolved.
Aug 14, 2020 at 4:22 AM
Good evening,
You cannot clean a catalytic converter. It may be clogged and preventing the engine from revving up.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
You could remove the pipe from the back of the turbo and drive it and see if it runs better. That would confirm the exhaust is not clogged.
Is the transmission shifting correctly?
Aug 14, 2020 at 8:53 AM
