Low oil pressure and check engine light?
269,503 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
COREYABRAM901
  • 10 POSTS
I was trying to figure out why oil isn't circulating through my system. I recently had an oil change but a few weeks later my low oil pressure light came on. I took it to AutoZone to check it out and found out the engine oil sensor light came on. I replaced the sensor and tested to see if any oil would come out of the hole the sensor was in nothing came out so i came to the conclusion the oil pump wasn't pumping. After replacing the pump it'll run for a few seconds and then turn right off.
Jul 16, 2023 at 1:51 AM
  • 110,245 POSTS
Is there any noise from the engine when it runs for a short bit? For example, do you hear a ticking or knocking from the engine?
If you had the oil pressure sensor removed, the oil should have come out, so I suspect you are correct. There is no pressure.
Let me know if you hear anything. Also, if you could record what is happening so I can hear the engine, it will help. Additionally, here is a link you may find of interest:
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Jul 16, 2023 at 2:05 PM
COREYABRAM901
  • 10 POSTS
Jul 16, 2023 at 10:23 PM
  • 110,245 POSTS
That does sound like there is no oil. Is there also an exhaust leak? The way it's running, I have a feeling it may need to be replaced. It isn't running on all cylinders. Also, when you cranked it the first time and it didn't start, it almost sounds like it was out of time. And I do hear internal bearing noises.
Let me know what I can do to help.
Jul 17, 2023 at 12:24 PM
COREYABRAM901
  • 10 POSTS
I had to replace the exhaust flange, so I had put in a flex line with a U-bolt to do a simple fix. I will look into it further to find out where the leak is coming from. What will make it not run on all cylinders? I will try to see if I can correct the timing. If you have the diagram for the timing marks, I am highly appreciative. Is the internal bearings something that's a difficult task?
Jul 17, 2023 at 2:54 PM
COREYABRAM901
  • 10 POSTS
I have taken the intake, intake plenum and valve covers to confirm if the pushrods and rocker arms are moving some are moving and others aren't if you have an idea on if it could be the camshaft or a failed lifter, please let me know. Thank you in advance for your help.
Jul 18, 2023 at 3:53 AM
  • 110,245 POSTS
If there is internal bearing damage, you are better off finding a replacement engine. As far as the valves are concerned, could you video what is happening and upload it for me to see? If the valves aren't moving,
As far as the lifters are not moving, the engine has hydraulic lifters. If you lost all oil pressure, that could be why you don't see movement.
I have a feeling either the oil pump has failed, or the pickup tube is clogged.
Jul 18, 2023 at 1:22 PM
COREYABRAM901
  • 10 POSTS
I recently replaced the oil pump with one I bought from rockauto. The screen didn't come with, so I gave it a thorough cleaning. I measured the screen pickup to make sure it wouldn't touch the bottom of the oil pan.
Jul 18, 2023 at 2:05 PM
  • 110,245 POSTS
I did notice that. Are they stuck open? I ask because it sounds like we have no compression on one or more of the cylinders.
Also, if you look down into the engine valley, you should be able to see the lifters and the cam. Not too easily, but you can see them. Have your helper crank the engine and see if there is any movement on the lifters and if you can tell if the lobe was damaged on the camshaft.
Jul 18, 2023 at 2:14 PM
