Low idle shake/misfire
160,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
CAMEREN TERVORDT
(Ecotec 2.2) When my car is idling it has a pretty good shake and the rpm's bounce between 500-1000 and now every now and then the vehicle says misfire detected on a scan tool, but will run perfectly fine when the code is cleared. any clue what may be wrong or what could be done to correct it? I have changed the coil pack/plug wires. I am going to try changing furl injectors.
Aug 14, 2016 at 9:53 AM
CAMEREN TERVORDT
The shake upon idle is not constant. it usually happens when either going from high speed to a stop or at a sudden stop.
Aug 14, 2016 at 9:54 AM
  • 55,682 POSTS
It sounds like it needs park plugs have you changed them?
Here is a guide that will help you
https://www.2carpros.com/articles/how-to-change-spark-plugs
Let me know what you find
Best, Ken
Aug 19, 2016 at 9:53 AM
CAMEREN TERVORDT
Brand new plugs were in it... ac delco iridium's... spendy, changed the coil pack with 3 different ones then changed the fuel injectors, runs fine now, thank you for the idea though
Aug 19, 2016 at 11:03 AM
  • 55,682 POSTS
Glad we can help please use 2CarPros anytime.
Aug 19, 2016 at 12:02 PM
