Low idle on brake sounds rough
TATSFARMBOY
  • 1990 FORD F-150
  • V6
  • RWD
  • 140,000 MILES
Truck starts up and idles great drives great only issue is that when im on the brake at a stop light the engine starts to shake doesn't day and if given a little gas the shaking starts. I plan on getting a tune up and replacing all the filters and fuel lines as well as spark plugs.
My question is if none of this works what could the problem be? A mechanic said its the torque converter or engine mount that don't make any since though. And the car passes smog fine
Sunday, January 18th, 2015 AT 2:26 PM
CJ MEDEVAC
  • 11,005 POSTS
GONNA THROW A BUNCH OF CRAP ON YOU
THIS MAY OR MAY NOT BE THE ISSUE
IT IS SOMETHING SIMPLE, AND NOT MENTIONED BY YOU SO FAR
TO KEEP MY SUPER SLOW HUNTING AND PECKING TO A MINIMUM. PLEASE READ "MY ANSWER" THAT I GAVE ANOTHER FELLER
https://www.2carpros.com/questions/engine-trying-to-stall-at-stop
THERE ARE LINKS IN THAT ANSWER TOO, THEY MAY HELP YOU IN SOME WAY TOO.
LOOKS LIKE YOU MAYBE DON'T HAVE A V-6 AS IN YOUR INFO ABOVE
I GUESSED YOU MEANT AN INLINE SIX, BELOW IN THIS LINK IS WHAT YOUR PART LOOKS LIKE
http://shop.advanceautoparts.com/p/bwd-idle-air-control-valve-21927/3488810-P?searchTerm=iac
RETURN TO THIS THREAD WITH GOOD NEWS!
THE MEDIC
Sunday, January 18th, 2015 AT 3:57 PM
