Low idle and random shutting off while driving?
123,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
CLARKE94
Low idle bubbling noise and does it while driving if stop at a stop sign.
Jul 7, 2023 at 4:13 PM
  • 55,721 POSTS
It sounds like the IAC valve needs to be replaced, but we should check it for vacuum leaks as well. Here is a guide to help with the vacuum leak. Please use this guide when the engine is cold only:
and this guide may help as well:
https://www.2carpros.com/articles/stall-at-idle
If the check engine light is on, we need to run the codes.
Check out the images (below). Please let us know what you find.
Jul 8, 2023 at 5:30 AM
