Heater not working properly in cold weather
287,103 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JR47
  • 116 POSTS
The car provides some heat but it's not enough in very low/cold temperatures. The car doesn't overheat or have any coolant leaks. I do have a low coolant light that pops on and off almost daily that's been narrowed down to being a bad coolant level sensor just haven't got around to changing it yet. Personally, I don't mind it but would like it to work properly when I have others in the car with me.
Feb 19, 2022 at 8:58 PM
SQM
  • 6,383 POSTS
This could be due to a stuck open thermostat.
If the thermostat fails in stuck open position, it will not allow the engine to reach operating temperature. Which will lead to the heater not being able to blow warm/hot air due to the coolant being lower than idea temperature.
Usually this will be noticeable on the temperature gauge, as it will not reach the operating temperature range on the gauge.
The operating temperature for this engine is 188F to 206F. So, if the engine is not reaching that temperature, it could be due to a stuck open thermostat.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Feb 20, 2022 at 11:45 AM
