Low ground reading
156,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
SCORLE
Replaced new transmission case motor due to 4wd needs service. Came up in code for replacement. Now code says low ground reading. 4.7 and should be at 6+. Any ideas?
May 31, 2019 at 5:27 AM
STEVE W.
  • 15,418 POSTS
Welcome to 2CarPros. Could you post the codes you had please? It sounds like a harness issue, but I want to look at the code setting criteria and wiring. Thank you.
May 31, 2019 at 5:38 AM
SCORLE
C1407 before transfer case replaced.
Jun 1, 2019 at 7:22 AM
STEVE W.
  • 15,418 POSTS
Okay, it sounds like a harness issue. I would pull the harness connector and check the pins for corrosion as well as pin fitment. A bad connection would cause issues with current flow.
Jun 1, 2019 at 10:34 AM
SCORLE
Thanks. Will do that.
Jun 2, 2019 at 1:28 AM
STEVE W.
  • 15,418 POSTS
Let us know what you find please.
Jun 2, 2019 at 10:34 AM
