low fuel pressure shuts off while idling
150,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBDIZZLE951
when the car is in gear it won't idle it'll shake sputter then shut off. while driving there is now power in the bottom end and not enough power to drive up steep hills. I thought it was the fuel pump at first affter testing the fuel pressure and replaced it but it did not work. i replaced the injectors and that did not work either i can't afford to just keep buying parts or take it to a shop any help or ideas will be greatly appreciated
Jan 25, 2014 at 7:38 AM
SATURNTECH9
  • 30,869 POSTS
Have you checked for excessive back pressure yet like a Plugged cat?
Jan 25, 2014 at 7:49 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
if the car revs freely in park and idles fine out of gear you could very well also have a torque converter or transmission problem. also check the air intake for blockages
Jan 25, 2014 at 8:45 AM
SATURNTECH9
  • 30,869 POSTS
Does the check engine light ever come on?When there is transmission issues those cars do set codes.
Jan 25, 2014 at 9:18 AM
