My son has the above vehicle which is flex-fuel but only uses E-10 fuel. When scanned it shows the codes for "lean both banks" but there is no "check engine" light. We can clear the stored codes and they will come back but still no "check engine" light. We checked for vacuum leaks but found none. We then checked the fuel pressure using a mechanical gauge. Key on-engine off, we have 60-62 PSI. When the engine is first started, we have 60 PSI but within a few seconds, the pressure starts to decline and stabilizes at 46 PSI where it remains. We also checked the pressure with a scan toll and got 45 PSI almost identical to the mechanical gauge. The vehicle starts readily and seems to run fine with no stalling nor misfires.
I have some questions: 1. Why do we not have a "check engine" light when we have trouble codes stored in ECM memory? 2. Since this is a "return-less" system is the pressure regulator/sensor inside the tank as a part of the fuel pump module? How does it work? 3. Can the sensor be reprogrammed using the correct scan tool to bring pressure up to proper specs seeing as how the pump is capable of 60 PSI? 4. Is it just the pump getting weak? 5. What would be the long-term effects of continuing to drive it with the 46 PSI fuel pressure?
Thank you in advance for your reply. Also thanks again for all the help in the past.
Dec 5, 2021 at 1:53 PM
