Low fuel consumption
2013 RENAULT SCENIC
57,000 MILES • 1.6L • 2WD • MANUAL
SUKI RANA
Owned car for six months now. Problem with fuel consumption. With a full tank only get 265-275 miles. With mpg of 24-25 mpg. Diagnostic fault was Knock sensor and Downstream oxygen sensor circuit. Had it serviced and changed knock sensor. But no change. Would changing downstream oxygen sensor circuit be the problem?
May 26, 2019 at 11:41 AM
  • 110,190 POSTS
Welcome to 2CarPros.
The oxygen sensors on vehicles signal the computer as to how rich or lean the engine is running. With that information, the computer adjusts the air / fuel mixture. If there is a fault with one of the sensors, the computer will run the vehicle in what is called a closed loop. Under those conditions, the computer will provide a rich fuel mixture to ensure the engine runs, thus using more fuel.
Here are three links for you to review. The first describes the purpose of the O2 sensor. The second link explains how to test one and the last explains how to replace one. Take a look through them. This is most likely something you can take care of yourself and save money.
https://www.2carpros.com/articles/how-an-oxygen-sensor-works
https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
If you decide to test the sensor, you will need a volt meter or multi meter. Here are two links explaining how to check wiring and how to use a volt / multi meter:
Let me know if this helps you or if you have other questions.
May 28, 2019 at 6:12 PM
