2001 Renault Scenic my Scenic will not start
ANDEMULLIN
  • 2001 RENAULT SCENIC
  • 4 CYL
  • FWD
  • MANUAL
  • 122,227 MILES
4 weeks ago my car developed a fuel pump fault. Had the fuel pump, sender & filter replaced. Following this the car refused to start. The new pump is feeding the fuel to the rails & the car is trying ever so hard to start. It is turning over but will not catch; had recent service before the probs and all coils changed 8 months ago. Tdc & maf sensors checked, icv and egr also checked and seem fine just will not start, somebody please help me?
Monday, May 24th, 2010 AT 2:58 PM
Check the fuel pressure if its within specs and also are the injectors pulsing.
Tuesday, May 25th, 2010 AT 4:40 AM
ANDEMULLIN
  • 6 POSTS
Fuel pressure seems within the necessary parameters, as for the injectors pulsing that would have to be established. I have also been told that there is a fuel sensor which controls the pulse of the injector which could also be the prob.
Anymore help would be greatly valued
Tuesday, May 25th, 2010 AT 5:29 PM
DAVE H
  • 13,384 POSTS
Check the immoboliser is OFF. If the dash light is flahing fast it is still ON or there is a fault. The immo system kills fuel injector function via the cars PCM/ECU
Sunday, May 30th, 2010 AT 3:37 AM
