Low engine power, low gas mileage
250,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
WENDALLT
In any gear my car wont rev up past 4000rpm, in neutral it revs up to the red line just fine. Acceleration is extremely sluggish, on a level road it takes a lot longer than it usually did to hit 60mph, on any sort of an incline it struggles to hit 30mph. Fuel cosumption has increased from 5.5 l/100km to 7.8 l/100km.
Theres no check engine light at all. I have cleaned MAF sensor and entire throttle assembly, replaced spark plugs, oil and air filter, had fuel pump and fuel pressure checked. Had cylinder pressure tested by mechanic who told me it is fine. Exhaust system is not clogged, piston rings are still in good condition. Installed a new clutch kit. Had all sensors tested by an auto electrician who saus they are fine. None of these attempts have fixed the problem at all and it seems to be getting worse.
I have noticed it take a while for oil pressure light to turn off upon start up, but topping oil by less than 1 piny seems to have stopped that. Any advice on what the problem might be?
Jul 8, 2019 at 5:25 AM
SCGRANTURISMO
  • 4,897 POSTS
What does your engine oil dipstick read?
Thanks,
Alex
2CarPros
Jul 8, 2019 at 8:08 AM
WENDALLT
It is at the halfway point when the oil light takes a while to turn off, once its topped up to full the light will only be on for less than a second when starting up.
Jul 8, 2019 at 1:04 PM
SCGRANTURISMO
  • 4,897 POSTS
Okay, the light is supposed to come on for a bulb check when you start up the vehicle. What does your engine oil dipstick read?
Thanks,
Alex
2CarPros
Jul 10, 2019 at 7:14 PM
