Low engine oil pressure light turned on and was making loud noise?
147,350 MILES • 3.5L • 6 CYL • TURBO • 4WD • AUTOMATIC
RICHER87
I immediately pulled over and shut the vehicle off and added two quarts of oil and had it towed. I have been told it needs an oil pump and timing chain kit. I don't know. Please help.
Aug 1, 2022 at 4:02 AM
SQM
  • 6,383 POSTS
So, when you add the two quarts of oil, was it actually low two quarts?
Low oil pressure light can come on if the oil pump is bad, also if the engine is very low on oil.
Typically, you will have to test the oil pressure to determine if the pump is bad.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
So, if the oil pump is bad it will need to be replaced. Also, the timing kit gets replaced as it is recommended to do so when changing the oil pump.
Let me know of any questions.
Aug 1, 2022 at 10:02 AM
RICHER87
No, it was about a half quart low but was past time for oil change. Several people told me to try adding diesel to my oil and let it idle for about 30 minutes then drain the oil pan and put new oil and new oil filter in it before buying the expensive parts.
Aug 1, 2022 at 5:30 PM
SQM
  • 6,383 POSTS
Well, the first step should be to test the oil pressure. Which can determine if the oil pump is good or bad.
Aug 2, 2022 at 2:37 PM
