Why after flushing radiator and refilling fluid the low coolant light stays on?
Oct 20, 2017 at 8:30 AM
HARRY P
✓Experienced Mechanic
Did you bleed the air out of the cooling system when you refilled it? If not, air in the system could be your problem. Also, make sure that your coolant reservoir is also full.
