Low coolant light stays on
200,000 MILES • 1.9L • 2WD
MICHELLE RALLS
Check the coolant container and it is full and the light will not go off.
Jun 26, 2018 at 10:20 AM
SATURNTECH9
  • 30,868 POSTS
Is the coolant tank filled to at least the seam of the coolant bottle? If so see if the back up light fuse is blown in the understood fuse box it is a 10 amp fuse. If that is blown it will cause that light to come on and stay on. If all that is good unplug the sensor on the bottom of the coolant bottle and jump across the connector to the coolant bottle. If the light in the dash goes out replace the coolant bottle.
Jun 27, 2018 at 6:51 AM
MICHELLE RALLS
Thank you. It was the thing on the bottom of the coolant tank. It needed to be cleaned. Now light is off. Thank goodness it was an easy fix. I really appreciate your help. I have had my Saturn eleven years now and paid only a grand for it. I have been truly blessed by this car.
Jun 27, 2018 at 1:48 PM
SATURNTECH9
  • 30,868 POSTS
Glad to hear it was a easy fix. I have had my 1999 Saturn twelve years now. Also, thanks for using 2carpros and please tell all your friends about us.
Jun 27, 2018 at 3:09 PM
MICHELLE RALLS
I sure will.
Jun 28, 2018 at 12:01 AM
