Is the coolant tank filled to at least the seam of the coolant bottle? If so see if the back up light fuse is blown in the understood fuse box it is a 10 amp fuse. If that is blown it will cause that light to come on and stay on. If all that is good unplug the sensor on the bottom of the coolant bottle and jump across the connector to the coolant bottle. If the light in the dash goes out replace the coolant bottle.
Jun 27, 2018 at 6:51 AM
