low coolant
162,000 MILES • 2.6L • 6 CYL • 2WD • AUTOMATIC
HEIMARKA
For the last 6 years, the coolant reservoir has stayed below minimum. If I add coolant, it spits it out and returns to the low level it prefers. I have had that looked at and gotten no answers. No warning lights or overheating has occurred. There are no leaks. 2 weeks ago I added 50/50 mix before a long trip. It spit it out and returned to its preferred level as always. There were no issues on this trip. 2 days ago, while driving on the highway the temperature gauge shot up to almost red, stayed there about 3 miles, then returned to normal just below half way. While driving in town, it ran slightly higher than normal, but normal at highway speeds. When idling at stop lights, the gauge crept up but returned to the middle range while driving again. At no time did the red indicator light for high temp come on, but the gauge constantly fluctuates and crept up while idling, running higher than normal while at low speeds. It ran normal temp on highway. The reservoir is now nearly empty, slightly lower than it usually runs, so I assume whatever issue prevented it from staying above minimum level has worsened and is now causing temperature issues within the system. I just don't know what the cause has been since the beginning.
Jun 6, 2021 at 7:40 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just a few questions first. Has any work been done on the cooling system? Has the thermostat or water pump ever been changed? Let us know and we'll go from there. Thanks for using 2CarPros.
Jun 6, 2021 at 10:30 AM
HEIMARKA
Hi, Danny. I can't say for sure, but it is likely both have been replaced. I bought the car 9 years ago when it was just under 100,000 miles. Just before that, it had major repairs done that likely included replacing both. It is possible that they have not been replaced though.
Jun 6, 2021 at 11:41 PM
DANNY L
  • 5,648 POSTS
Hello again.
It's possible you might have a defective thermostat that might be causing this issue. Here is a tutorial on how to replace a thermostat:
I've attached picture steps below on how to replace the thermostat on your car. Hope this helps and thanks again for using 2CarPros.
Jun 7, 2021 at 12:33 AM
HEIMARKA
Thank you, I will try that and see how it goes.
Jun 7, 2021 at 12:44 AM
DANNY L
  • 5,648 POSTS
Hello again.
Okay. Keep us updated and let us know if any problems arise or you have any further questions on this issue. Thanks again for using 2CarPros.
Danny-
Jun 7, 2021 at 1:53 AM
