Okay, but mystery oil in cylinders let sit turned over very slow let sit another 24 hours turned over very fast to blow all oil out of cylinders did another compression test now have 190,180,180,190,190,and 180. When I was doing this# 4 cylinder was building compression then quit. This was not a cylinder that was washed. Put a little mystery oil in cylinder and started to build compression again. Turn over very fast again to get oil out of cylinder and let sit. Then did compression test and the numbers are what I have now. All the cylinders that did not get washed have improved from around 100 to 180. And #2 and #5 that got washed went from 30 to 190. Now all cylinders are only 10lbs different and have good compression. I'm really baffled on this one. Was thinking of doing a leak down test just to make sure that they hold this compression. Any ideals maybe a valve sticking then when builds compression it unsticks due to mystery oil? Help please
Jan 27, 2020 at 11:25 AM
