Low compression in one cylinder
188,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
WILLIAM GIERCZAK
Cylinders 1 ,2, and 3 have 170 lbs. of compression, number 4 only 20. is it repairable?
Feb 17, 2019 at 9:39 PM
Good afternoon,
Sure it is but it all depends on why it is low.
It could be:
1. Burned valves. This would be a valve job on the cylinder head.
2. Piston rings. This involve an overhaul of the motor.
3. Burned hole in a piston.. This would also mean a overhaul.
Feb 18, 2019 at 2:32 AM
SCGRANTURISMO
  • 4,897 POSTS
Yes it is repairable. I have included a link for you below to help determine the cause of low compression in that cylinder. Go through it and get back to us with what you find out.
https://www.2carpros.com/articles/the-reasons-for-low-compression
Thanks,
Alex
2CarPros
Feb 18, 2019 at 2:35 AM
