I had a used engine installed and the car is experiencing a misfire in the fifth injector. Does that mean engine is no good? Car drives good but when you stop it is shaking a little or if engine is running you can see a little shaking in the engine. I replaced the fuel injector and put in new spark plugs. Mechanic seems to think engine is bad.
Jun 2, 2018 at 12:29 AM
