low compression cylinder 4
150,000 MILES • 1.6L • 4 CYL • MANUAL
ANDRE06
Hi heres the problem i have 1,2,3 cylinders 10.5 bar the fourth cynder 4.5, abolutely no oil consumption but when i put a little oil in the 4th cylinder the compression rises to 10 +, The car runs normally above 1200 revs but if i let it tick over for a few secondsit runs on 3. no smoke, oil consumption, lots of smoke if i pour a little oil into the 4th cylinder untiil the oil is burnt. Any ideas or advice well appreciated.
Andre
Aug 11, 2019 at 9:58 PM
  • 55,732 POSTS
Hello Andre,
Can we double check the year of the car? 1993? It sounds like you have broken piston rings which is common, for this we must take apart the engine or get a rebuilt or used unit. Let me know what you want to do so I can send instructions.
Aug 13, 2019 at 3:24 AM
