I had the compression test done, and was told that the replacement of the right cylinder head needs to be replaced. Do they mean that the right cylinder head gasket is needed? I was told that the part is $5,784.00, and with labor $8,000.00. However, when I look online, the part is only a couple of hundred dollars. I want to confirm that when they say replacement of the right cylinder head, they are referring to the right head gasket.
May 17, 2018 at 10:35 PM
