Low compression
207,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
TREASUREMOUNTAIN1
can low compression in one cylinder cause my A/C to not work
Sep 8, 2020 at 4:48 AM
Anything is possible but it is highly doubtful. If the A/C is not working let's get a post started for that issue and address the low compression on this one.
Here is a guide that covers low compression:
https://www.2carpros.com/articles/the-reasons-for-low-compression
We need to start a new post for the A/C issue because we need to keep each post to the topic listed in the subject so that others can find them if they are having similar issues. Due to an A/C issue most likely not being related, we should start one under that heading and address those issues.
Let me know what you are finding with the compression and go from there. Thanks
Sep 8, 2020 at 4:59 AM
