LOW BRAKE PEDAL WITH ENGINE RUNNUNG
4 CYL • FWD • AUTOMATIC
KEVIN79
PEDAL GOES TO FLOOR WITH ENGINE RUNNUNG. HAVE BLEED BRAKES REPLACED MASTER CYLINDER. PEDAL IS HARD WITH ENGINE OFF BUT GOES TO FLOOR WITH ENGINE RUNNING. VEHICLE IS EQUIPED WITH ABS. CAN SOMETHING BE BYPASSING IN ABS UNIT.
Aug 27, 2014 at 2:01 AM
HMAC300
  • 48,601 POSTS
no have a pro bleed it you have air in abs unit and he has to use scanner to open valves to bleed
Aug 27, 2014 at 2:28 AM
