low brake pedal
167,000 MILES • 4 CYL • FWD • AUTOMATIC
DON52
Have replaced both front pads and rear shoes. Bled brakes numerous times starting at the right rear an moving around vehicle ending at left front. The bleeders are above the brake lines. There seems to be no difference when the engine is running to when it is turned off. The brake pedal will actually bottom out.The rear brakes shoes are dragging. Pumping the pedal helps slightly.
Mar 14, 2016 at 1:16 AM
HMAC300
  • 48,601 POSTS
try a power brake bleeder there is air in abs unit if that doesn't work then a pro will have to use a scanner to do it
Mar 14, 2016 at 2:54 AM
DON52
It is not equipped with abs.
Mar 14, 2016 at 5:24 AM
RENEE L
  • 1,260 POSTS
I suggest checking the master cylinder it sounds like it's not returning all the way due to the seals not working properly. Please let me know if that helps you.
Mar 17, 2016 at 8:50 AM
