Low beam problem
250,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
ITANCAN
I ran into a deer and after that low beams were working, after I changed the headlamp on the driver side where the deer hit,the low beams dont work,just the high beams
Nov 15, 2017 at 9:54 AM
  • 110,251 POSTS
Have you checked the main headlight fuses under the hood in the power distribution box? I believe there are two separate fuses, one for hi and one for low beam. Check that first.
Nov 15, 2017 at 12:47 PM
