low beam plug
167,000 MILES • 6.0L • V8 • 4WD
CODY HOWLAND
My driver side low beam plug burned out. I changed it several times all other lights work fine, bulb works on passenger side, but when I hook new wires to driver side melts plug.
Sep 15, 2016 at 9:20 AM
CJ MEDEVAC
  • 11,000 POSTS
Just a possibility
Maybe the actual connector(s) inside the plastic are Sprung (not gripping its mate tightly) or corroded. This "loose" connection would get really hot and melt the plastic housing.
An auto parts store should have that whole pigtail and also have butt splices to connect the wires back together.
Also check the light housing for it holding water (may be cracked) water sloshing on the hot light.
I am banking on my first guess!
Let me know what you find!
The Medic
Nov 17, 2017 at 3:53 AM
