Accelerator pedal skips a little bit on take off at low rpm's
162,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
COLBY532
Gas pedal skip a little bit on take off, good power, good fuel mileage, low rpm skip. Check engine light comes on three to five miles down the road computer will not scan it comes up as error. Tried three different times at Advanced Auto. New fuel system, heating system, alternator, water pump, plugs, and coil pack. No gas smell. As long as you do not step on it hard it will take off smooth and good.
Oct 23, 2018 at 11:25 PM
  • 55,746 POSTS
This sounds like an ignition issue do you have new plugs wires cap rotor? I would use all AC delco stuff here is a guide. Service the throttle body as well.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Please run down this guide and report back
Cheers, Ken
Oct 25, 2018 at 12:08 PM
COLBY532
New plugs and coil packs. 4 cylinder 2.2 no distributor 95 S10. Has the low end Skip cold warm wet or dry. If it had vacuum advance that's what I'd said it was acting like . Just touch the gas pedal it skips a little bit then comes out of it. Engine is a 4-cylinder with no distributor has sensors
Oct 27, 2018 at 9:43 AM
  • 55,746 POSTS
Okay cool. So it acts more like a hesitation? Can you please shoot a quick video with your phone so we can hear the noise, that would be great. You can upload it here with your response. In the meantime let's service the throttle body. Here are two guides that can help.
https://www.2carpros.com/articles/engine-hesitates
and
Please run down these guides and report back
Cheers, Ken
Oct 28, 2018 at 3:53 AM
