low air volume on defrost
160,000 MILES
LJSCHNEIDER
Nov 7, 2025 at 6:22 PM
LJSCHNEIDER
I have installed new both HVAC Blower Motor and Blower Motor Resistor. I suspect Mode Door Actuator.
Nov 8, 2025 at 5:47 PM
  • 55,845 POSTS
Yep, you would be correct, is the mode blend door actuator is weak or the gears inside broken the door will not close completely. Here is a guide to show you where the mode actuator is, scroll down to the bottom of this guide for more information.
Please a short video in your response of the problem, so we can see what's going on.
Nov 9, 2025 at 2:44 AM
LJSCHNEIDER
Ken, I'm a bit confused! The link you sent me "Replace a HVAC Air Blend Door Actuator with Calibration" seems to be f
Nov 9, 2025 at 3:23 AM
LJSCHNEIDER
Sorry, hit the wrong button.
I'm a bit confused! The link you sent me "Replace a HVAC Air Blend Door Actuator with Calibration" seems to be for the Blend Door Actuator and not the Mode Door Actuator. Do you have a Video for the Mode Door Actuator Install? If not, I believe it is located above the accelerator. Am I correct!
Larry
Nov 9, 2025 at 3:31 AM
  • 55,845 POSTS
Hi Larry,
Yes, that is the correct guide, scroll down to see the location of the mode actuator for the HVAC system. This will be the one you need to change out. Please let us know what happens.
Nov 10, 2025 at 1:01 AM
LJSCHNEIDER
Thank you
Larry
Nov 11, 2025 at 1:13 AM
  • 55,845 POSTS
You are welcome, please let us know if you need anything else to fix the problem.
Nov 11, 2025 at 1:59 AM
