Low air flow
200,000 MILES
GREG RUSSELL
I turn on my air low medium high barely any air comes out of the vents hot comes out. When it is on hot cool comes out. When it is on AC but barely any air flow out the vents.
Oct 17, 2018 at 9:45 AM
  • 55,746 POSTS
It sounds like you have a weak blower motor or a mode door actuator that is not working. Does the blower motor sounds like it working good fast? If so here is the location of the mode door actuator and guides to help. Check under the hood for a small vacuum line running into the firewall make sure it is connected this guide will show you what to look for.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
and
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
Cheers, Ken
Oct 18, 2018 at 11:53 AM
