whining from rear end
12,200 MILES • V8 • 2WD • AUTOMATIC
CJGWYNN
Loud whining from rear end seems to be the passenger side I have replaced both of the hub assembly's but i need to re tighten since they are leaking
just need a new direction to go on this can you help? I am a 50 year old female and I try to do all the work myself
Jun 8, 2014 at 4:55 AM
  • 110,248 POSTS
What is leaking? Have you checked the differential fluid?
Jun 8, 2014 at 2:10 PM
CJGWYNN
rear hub assemblys are leaking they are new I need to tighten is there a torque recommendation for this ? also original problem is still there rear end is a loud whinning-howling at 40 plus miles per hour thought it may have been hub assemblys now still happening. I also changed out differential fluid differential inner gears look great no pitting or metal shavings at all .. what ya think
Jun 8, 2014 at 9:37 PM
  • 110,248 POSTS
Chances are it is a bearing in the differential. It could be one of the pinion bearings, or one of the bearings on the yoke (one inside the diff and one on the outside under the pinion seal. As far as just looking, it is hard to tell. It will actually need taken apart to see if there is damage to the roller bearings or the race.
Jun 9, 2014 at 10:15 AM
