Loud whine and some idling problems?
210,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
74BOSSK
When I start the truck, there is a very loud whining or hissing sound coming from the engine bay. After a few seconds of idling, the idling feels almost like a misfire, but straightens out when moving. When accelerating, the high pitch sound gets quieter and lowers in pitch with the load until I let off the gas, at which point it gets loud again. Once I turn it off, the whine seems to wind down and fade out for a few seconds.
May 25, 2023 at 5:03 PM
  • 110,248 POSTS
Based on your description, it sounds like you have an engine vacuum leak. That is the first thing I would recommend looking for.
Here is a link that explains how to locate and repair a leak:
Try this and let me know if it helps. If you are unable to find a leak, let me know. Also, in the event no leak is found, record the noise and upload it for me to hear. However, what you described is exactly how a leak would react.
Let me know what you find.
joe
May 26, 2023 at 3:44 PM
74BOSSK
Thanks for responding. I have to say as I've worked with it I think it most definitely a vacuum leak. So far I haven't been able to find where it is, so I'll just have to keep looking. It just sounds like it is coming from everywhere.
May 26, 2023 at 4:39 PM
  • 110,248 POSTS
Try using carb cleaner as mentioned in the link I attached. It will cause the engine RPMs to change if you hit the area that is leaking.
May 27, 2023 at 6:35 PM
