After hearing the noise from the rear from the rear passenger tire, I pulled over thinking it was flat. However, it seemed till I pushed on the tire. It has some play in it almost as if the lug nuts are not fully tightened down yet they don't budge when I try to tighten them. Is this a tie rod or ball joint issue?
Jan 9, 2023 at 5:05 AM
