Loud tick/rattle from engine bay when starting from cold and under 2000 revs
2007 VAUXHALL ASTRA
70,000 MILES • 1.7L • TURBO • 2WD • MANUAL
TIMWISER
This noise has started on our diesel Astra since the weather got cold. The ignition is started and it begins pretty much straight away. If the engine is revved a little, taking it past 1800/2000 revs, the noise goes away until the revs drop down again. After a few mins of driving, the noise goes away. If the engine is warm, the noise doesn't occur.
There's no lights on the dashboard indicating any fault.
I've recorded the noise and put it on my OneDrive account. You can hear it at http://1drv.ms/1yZGAKs
Feb 8, 2015 at 5:47 PM
DR LOOT
  • 2,311 POSTS
first of all reving a diesel when its cold is not recommended, it sounds like because the weather's getting cold you may have a weak battery causing the alternator to overwork to charge it back up and the belt is loose on the alternator. once the battery is charged up the noise goes away
Feb 11, 2015 at 12:12 AM
