Loud squeaking noise
133,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
TYLER_SCHAFFER
Recently I have had a loud squeaking noise coming from under the car. It’s not the belts or anything I check those, it doesn’t happen when idling. It only happen when going accelerating and reversing. I have looked under the car and couldn’t find any rubbing or clear signs of metals scratching anywhere. I don’t want to take it to a mechanic if it’s something I can fix on my own.
Mar 29, 2019 at 6:26 AM
JOETECHPRO
  • 705 POSTS
Hey TYLER_SCHAFFER,
Does it happen at low speeds on flat ground?
Or is is only when accelerating/over bumps?
If so can you get someone to walk beside the vehicle to identify which wheel/area the noise is coming from that will be a good start.
If it is only over bumps can you reproduce the noise by pressing down on each corner of the vehicle to compress the suspension?
If you can upload a video that will also help us point you in the right direction.
Regards, Joe
Mar 29, 2019 at 10:28 AM
