2007 Chevy Tahoe Squeak after replacement
2007 CHEVROLET TAHOE
86,000 MILES • V8 • 4WD • AUTOMATIC
MISSASUE62006
Replace front and rear brakes but still sqeak when stopping as well as a slight squeel turning. Have had speed sensor replaced within the last 6 months. Also noticed while replacing pads front passenger side was well worn while the driver side was almost new from previous replacement a year ago.
Jun 29, 2010 at 1:04 PM
KHLOW2008
  • 41,814 POSTS
Hi missasue62006,
Thank you for the donation.
The passenger side pads wearing off indicates a fault with the calipers or brake lines and this could cause the rotors to warp resulting in the squeaking noise.
Check the caliper pistons for sticking and a warped rotor.
Jun 30, 2010 at 6:42 AM
