when going over bumps big and small i have this loud metallic sound like a bag of washers or loose linkage sound. i replaced sway bar bushings and end links i thought maybe the front half shaft was not disengaged fully. Also, the boot was ripped so changed half shaft i checked heat shields front brake calipers. Sound does not abate when applying brakes. I have been working on this for 2 weeks. So, today while my wife drove i rode in the back and it sounded as i described like loose linkage or bag of washers and from where i was riding it sounded like it was coming from the area between cab and bed. it's like a (chincky chink sound only when going over bumps sounds like something is really loose down there its very loud now... thank you
Mar 13, 2024 at 11:58 AM
