Loud popping sound and jerking
2017 TOYOTA CAMRY
70,000 MILES • 2.4L • 4 CYL • 2WD
CHRIS STYLES HERBERT
While sitting still, I turned my steering wheel all the way left and a popping sound with a jerk happened. What could it be?
Sep 22, 2019 at 11:57 AM
This sounds like a suspension component but the issue is there is no easy way to tell you which one with out some inspection and diagnosis.
Here is a guide that goes through the basic items:
https://www.2carpros.com/articles/popping-noise
I suspect you have a loose bushing but as I said we are going to have to inspect them to be sure. Can you get a recording of the popping noise? Maybe one from inside the vehicle and then one from outside on the sound that it is the loudest?
Sep 22, 2019 at 12:51 PM
