Loud pop then smoke
10,000 MILES • V8 • TURBO • 2WD • MANUAL
SVANDERSON
A few months ago I was told that my turbo was leaking (whatever that means) but as long as my car wasn't smoking it was fine for the time being. However, last night I was in first gear and attempting to get up a slightly steep hill, I heard a pop and then a bad smell started. It wasnt until i was all the way up the hill that my car started smoking pretty bad. Once turned off it cooled down a bit but was still smoking a bit. I haven't driven it since.
Mar 4, 2020 at 2:18 AM
Good afternoon,
What color was the smoke?
The turbo may have failed. Does the car have less power?
Removal
a. Remove airbox assembly with all attached sensors
b. Remove air duct between charge air cooler and intake manifold
c. Remove intake air duct between charge air cooler and turbocharger.
d. Remove oil and coolant lines connected to turbo unit
e. Remove heat shielding, if required for clearance.
f. Disconnect downpipe and catalytic assembly
g. Unbolt turbocharger from exhaust manifold, remove turbo unit.
Installation
Installation is reverse of removal.
Editor Note: Oil supply lines for turbo along with engine oil and filter should be replaced when installing a replacement turbocharger.
Prior to reinstalling turbo unit, remove any remaining gasket material and ensure that turbo mounting surface is clean. Reinstall with new gasket.
Before restarting engine be sure to prime turbo oil supply.
Before starting vehicle, the turbocharger oil drain hose should be disconnected from the oil pan and the engine should be turned over with starter until oil is running out of the oil drain hose. This will ensure that the turbo is lubricated before initial start-up.
Turbocharger system components, removing & installing
Part I
1. 40 Nm
Coat threads with G 052 112 A3
2. Seal
3. 10 Nm
Must not be loosened
4. Pressure unit
For charge regulator valve in turbocharger
Can only be replaced in conjunction with turbocharger
Checking charge pressure regulation, refer to Testing and Inspection - Procedures
5. Circlip
6. Turbocharger
Checking charge air pressure control, refer to Testing and Inspection - Procedures
Charge air pressure control valve and charge air pressure control valve vacuum unit are components of the turbocharger and cannot be replaced individually.
Fill turbocharger with oil via connection before connecting oil supply pipe.
After installing turbocharger run engine at idling speed for approx. 1 minute and do nut rev up, to ensure oil supply for turbocharger.
7. O-ring
Always replace
8. 10 Nm
9. Intake pipe
10.Gasket
Always replace
Note installed position
11.20 Nm
12.Heat shield
13.10 Nm
14.Banjo bolt, 30 Nm
15.Oil supply pipe
16.30 Nm
Always replace
Coat threads and bolt head seating surface with G 052 112 A3
17.Exhaust manifold
18.Gasket
Always replace
19.20 Nm
20.Banjo bolt, 30 Nm
21.25 Nm
Always replace
22.Banjo bolt, 35 Nm
23.Coolant return pipe
24.25 Nm
25.Spacer sleeve
26.Banjo bolt, 35 Nm
27.10 Nm
28.Coolant supply pipe
29.Banjo bolt, 35 Nm
30.30 Nm
use only original bolts from parts catalog
31.Support bracket
Between turbocharger and cylinder block
32.25 Nm
33.Gasket
Always replace
34.Gasket
Always replace
35.10 Nm
36.Oil return pipe
To oil pan
37.10 Nm
38.10 Nm
Do not alter setting
Must not be loosened.
Mar 4, 2020 at 5:50 AM
SVANDERSON
Hello!
The smoke was white I believe.
Mar 4, 2020 at 7:00 AM
If it was white, that would indicate you are burning coolant which means a possible head gasket.
I would do a compression test to see if the pressure drops indicating a leak from the head.
If it was blue, it would zero in on the turbo.
Mar 4, 2020 at 7:07 AM
SVANDERSON
Awesome, thank you so much for your help!
You are welcome.
Always glad to help.
Mar 4, 2020 at 7:14 AM
SVANDERSON
Hello again!
I should have asked this yesterday, do you think my car is okay to drive to work and then the shop? I would have to go on the freeway about 2 exits down...
Mar 5, 2020 at 12:46 AM
Try driving it around the block a couple of times and see if it performs well.
Mar 5, 2020 at 10:08 AM
