Clutch replaced by mechanic less than 1000 miles, 6 months ago. Now when clutch pedal is depressed all is fine until the last 1inch before the floor. At that point there is a loud grinding scraping noise. The clutch pedal can be depressed until the truck is free wheeling and coasting, but if you press it the last inch to the floor, it makes a horrible grinding scraping noise. Please advise and explain why. I suspect the trrow out bearing. Thankss. Mike
Jan 5, 2015 at 9:05 AM
