Loud noise started, noticed coolant leakage shortly after
2008 MAZDA CX-7
182,317 MILES • 6 CYL • TURBO • AUTOMATIC
TOMICA WHITE
About a month ago, the serpentine belt came off while I was driving. I got the belt replaced, a week later my heat goes out, so I added some coolant and the heat started working again. About a week ago, i started the car and i usually have to let it run about 5 mins before taking off or it'll die as soon as i try to pull out, but i notice a new noise. I pop the hood and notice that one of the pulleys is wobbly. I need to know if the pulley is bad, or if it's the water pump connected to that pulley. Also, my A/C does not work and I've done everything to try and get it to work. Any advice would be appreciated.
Jan 3, 2021 at 11:10 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
What we ask for you to do is to use your cell phone and make a video or take pictures and upload here. This way we can be on the same page and see what pulley is giving you concern. Get back to us and we'll go from there. Hope this helps and thanks for using 2CarPros.
Jan 4, 2021 at 10:35 AM
