Code p0017
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
BADBOYROD
  • 16 POSTS
Loud noise. How can I fix this? where is the location of sensor at? please help.
Mar 28, 2022 at 10:13 AM
  • 110,248 POSTS
The code doesn't identify a specific sensor in need of replacement. Instead, it indicated there is a correlation issue between the crankshaft position sensor and the bank 1 exhaust camshaft position sensor. Basically, something is causing the two to be out of sequence with each other.
Since the vehicle only has 90,000 on it, chances are the camshaft position sensor is the problem, but I can't be 100% sure.
Do me a favor. Take a look below at the two pics I attached. The first one explains the code and the second starts the diagnostics. In this situation, I need to know if any of the codes listed in pic 2 are also set. If they are, the focus will be on it or them if not, we have two things to do. Have a live data scan tool to check the sensor or replace it and hope that's the problem.
If that is the route you want to take, let me know and I'll provide directions and how to locate the correct sensor.
Mar 29, 2022 at 11:07 AM
BADBOYROD
  • 16 POSTS
There are no other codes except P0017. I would just like to replace the sensor. Can you provide directions and how to locate the correct sensor?
Mar 29, 2022 at 11:26 AM
  • 110,248 POSTS
I believe you had two threads going. I provided directions on the other one. Please confirm that you received them.
Take care and let me know if you have questions.
Mar 29, 2022 at 1:37 PM
BADBOYROD
  • 16 POSTS
Okay, got them. Thank you, Joe, I will let you know.
Mar 29, 2022 at 7:25 PM
  • 110,248 POSTS
No problem whatsoever. And you are very welcome. We need to get this thing running properly.
Take care of yourself and I'll watch for your reply.
Mar 30, 2022 at 12:25 PM
BADBOYROD
  • 16 POSTS
This is to my first question p0017, Camshaft Position Correlation Bank 1 Sensor B, where is this located at?
Mar 31, 2022 at 11:18 AM (Merged)
  • 110,248 POSTS
I just answered your other question. As far as the sensor is concerned, it is the bank 1 exhaust camshaft position sensor. I attached a picture below showing its location. (Pic 1)
As far as replacement, the last two pics provide directions specific to this vehicle.
Please understand, the sensor itself may not be the problem, but it certainly is possible.
BADBOYROD
  • 16 POSTS
Hello Joe, everything worked out good thanks for your help, I have another question about another vehicle 2013 Chrysler 200 2.4 LX 96,200 miles, A/C door blend actuator, clicking noise. I need a location where the third one is I found two of them on passenger side. Can you send me pictures of where it is located at, please? Thank you
Apr 9, 2022 at 6:20 AM
  • 110,248 POSTS
I'm glad to hear you got it fixed. As far as the new question, I would be happy to help. However, I need to ask a favor. We try to keep the threads specific to one topic, so they are more helpful to others. Because of that, could you copy and paste your new question onto a new thread?
Here is the link to start it:
I truly hope you understand. I will watch for your new post.
Take care of yourself,
Apr 9, 2022 at 2:10 PM
